Hello,
Based on bundle plugin for sw6 I want to create a different logic and not using custom fields.
Steps:
Create a new column in product table
use EntityExtensionInterface to a add a new Json Field
Create a subscriber on product loaded and load data into product.extensions.newColumn
Create in admin product edit a sw-entity-multi-select where I want for one product to assign more products in a json
Load list of available product for selection, pre-populate assigned products, save select on each change
Most of the work is complete but I stopped when wanting to save the new column value via the admin api call.
For example:
POST
http://domani.com/api/v1/product/05e1008fc06343578492a76d2196a7c9/extensions/newColumn
Body:
   “yyy”: “xxxx”
Returns:
“errors”: [
“code”: “0”,
“status”: “500”,
“title”: “Internal Server Error”,
“detail”: “Attempted to call an undefined method named “getReferenceDefinition” of class “Shopware\Core\Framework\DataAbstractionLayer\Field\StringField”.”
This neither is possible:
PATCH
“newColumn”: {“xxx”:“yyy”}
Â
Please advise if the above is possible .
Â
We wanted to display the field separately from custom fields sets for an easier navigation/usage.
We can switch to many to many select with a new table for our parent / child products if not possible as we wanted into a simple json field.
Â
Thank you,
AndreiB.
