- Some Products has multiple „main“ images. But I see only one if I check the product with the API endpoint
store-api/product/productid, is there a different endpoint for checking images ? - I need the image from „Citrus-Quark“, but there is no
mediaIdor media, but it has a different image in the frontend. How can I get it then?
The Shopware 6 store-api docu is a little slim.
"options": [
"groupId": "16f64239b6b14be9b0c173f10e415105",
"name": "Citrus-Quark",
"position": 0,
"colorHexCode": null,
"mediaId": null,
"group": null,
"media": null,
"_uniqueIdentifier": "6a8f8be85eed4097bba6866cf220cab5",
"versionId": null,
"translated": {
"position": 0,
"customFields": {
"emz_migration_legacyId": 1985
"createdAt": "2022-05-21T21:00:00.822+00:00",
"updatedAt": null,
"extensions": {
"foreignKeys": {
"apiAlias": "array_struct"
