Load all variants of a product (PHP)
I am trying to load all variations of a product.
While using google I found this code snippet:
class ProductViewSubscriber implements EventSubscriberInterface
    private EntityRepositoryInterface $productRepository;
    public function __construct(EntityRepositoryInterface $productRepository)
        $this->productRepository = $productRepository;
    public function getVariantsOfProduct(SalesChannelProductEntity $product, Context $context): EntitySearchResult
        $parentProduct = $product->getParent();
        if ($parentProduct != null) {
            // We need the parent product to find all variants
            $product = $parentProduct;
        $criteria = new Criteria();
        $criteria->addFilter(new EqualsFilter('product.parentId',
            $product->getUniqueIdentifier()));
        return $this->productRepository->search($criteria, $context);
    public static function getSubscribedEvents(): array
        return [
            ProductPageLoadedEvent::class => ['addVariants'],
    public function addVariants(ProductPageLoadedEvent $pEvent)
        $products = $this->getVariantsOfProduct($product = $pEvent->getPage()->getProduct(), $pEvent->getContext());
        $matchingVariants = $products->getElements();
But using the code snippet only an empty list is returned, though there are definitely variants to that product. How can I fix this code?
change new EqualsFilter('product.parentId', to new EqualsFilter('parentId',
