How to animate elements on a banner
Hello, I´m using „Digital Publishing“ to create banners and elements on it (like texts, images atc.). I have animated.css file uploaded on my web and I animated these elements. But the animation is done only once, then is the element animated no more, just one time.
I have now one slider with 3 banners/images (you can switch between them with arrows or dots) and I would like the elements to be animated everytime when a next image comes. I mean that I want these animations to start everytime I switch one image to other. The slider can be found here (www.futureindustries.co).
Thanks for any advice.
Sounds like you’ll have to implement an event that’s always triggered when you move around the images. Probably write a jquery function that’s triggered each time 'n starts this kind of animation somehow… Not a jquery expert so you’ll need to check if there’s such a thing though…
