Please provide the solution for run my plugin testcases
if you need an example for PHPunit and how to test a plugin, you can have a look at one of our plugins at GitHub: GitHub - shopwareLabs/SwagBackendOrder: plugin which allows you to create orders via backend module
If you have further questions, feel free to ask ![]()
Viele Grüße aus Schöppingen
Michael Telgmann
While run the phpunit in my plugin folder, I got the following error,
PHP Fatal error: require_once(): Failed opening required ‘PHPUnit/Framework/TestCase.php’ (include_path=’/var/www/shopware/engine/Library:.:/usr/share/php:/usr/share/pear:’) in /var/www/shopware/engine/Shopware/Components/Test/Plugin/TestCase.php on line 46
