Habe das Problem, wenn ich auf Bestellungen im Backen klicke, dann kommt folgende Fehlermeldung:
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‚SELECT s0_.id AS id_0, s0_.orderID AS orderID_1, s0_.articleID AS articleID_2, s0_.taxID AS taxID_3, s0_.tax_rate AS tax_rate_4, s0_.status AS status_5, s0_.articleDetailID AS articleDetailID_6, s0_.ordernumber AS ordernumber_7, s0_.articleordernumber AS articleordernumber_8, s0_.price AS price_9, s0_.quantity AS quantity_10, s0_.name AS name_11, s0_.shipped AS shipped_12, s0_.shippedgroup AS shippedgroup_13, s0_.releasedate AS releasedate_14, s0_.modus AS modus_15, s0_.esdarticle AS esdarticle_16, s0_.config AS config_17, s0_.ean AS ean_18, s0_.unit AS unit_19, s0_.pack_unit AS pack_unit_20, s1_.id AS id_21, s1_.detailID AS detailID_22, s1_.attribute1 AS attribute1_23, s1_.attribute2 AS attribute2_24, s1_.attribute3 AS attribute3_25, s1_.attribute4 AS attribute4_26, s1_.attribute5 AS attribute5_27, s1_.attribute6 AS attribute6_28, s1_.neon_improveorderedvariants_selectedvariants AS neon_improveorderedvariants_selectedvariants_29, s1_.neon_improveorderedvariants_selectedvariants_text AS neon_improveorderedvariants_selectedvariants_text_30, s1_.pickware_canceled_quantity AS pickware_canceled_quantity_31, s1_.neti_recommendation AS neti_recommendation_32, s1_.neti_redeemed_points AS neti_redeemed_points_33, s1_.neti_multiple_vouchers_vouchercode AS neti_multiple_vouchers_vouchercode_34, s1_.dvsn_return_status AS dvsn_return_status_35, s1_.dvsn_return_quantity AS dvsn_return_quantity_36, s1_.dvsn_return_reason AS dvsn_return_reason_37, s1_.dvsn_return_comment AS dvsn_return_comment_38 FROM s_order_details s0_ LEFT JOIN s_order_details_attributes s1_ ON s0_.id = s1_.detailID WHERE s0_.orderID IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)‘ with params [104, 97, 95, 89, 86, 82, 72, 69, 52, 50, 47, 45, 37, 35, 33, 31, 26, 24, 22, 20]: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‚s1_.dvsn_return_status‘ in ‚field list‘ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 131 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(855): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‚SELECT s0_.id A…‘, Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‚SELECT s0_.id A…‘, Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(321): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(962): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(917):
Ich habe den Verdacht, dass es mit der nicht vollständigen Installation von dem Plagin (Google Shopping Professional) zu tun haben könnte.
Habe das Plagin deinstalliert und alle Cache gelehr und alles neu kompiliert, aber ohen Erfolg.
Könnte mir jemend weiterhelfen bei diesem Problem?
Besten Dank im Voraus für Eure Bemühungen.
Gruss Alex
www.nanomarkt.ch
