bei meinem Shopware 6 Shop www.holsteinhydraulik.com
funktioniert seit 8.5.2020 die Generierung der sitemap nicht mehr.
https://www.holsteinhydraulik.com/sitemap.xml
Verwendeter Softwarestand: 6.3.0.1
http://www.sitemaps.org/schemas/sitemap/0.9">
2020-08-05T17:35:04+02:00
Der Fehler im Log ist:
Failed rendering string template using Twig: Failed rendering string template using Twig: Impossible to access an attribute (“getBreadCrumb”) on a null variable in “caaefb867ad22e2cb6ea794735187802” at line 6.
{“source”:“core”,“environment”:“prod”,“additionalData”:{“exception”:“Shopware\Core\Content\ProductExport\Exception\RenderProductException: Failed rendering string template using Twig: Failed rendering string template using Twig: Impossible to access an attribute (“getBreadCrumb”) on a null variable in “caaefb867ad22e2cb6ea794735187802” at line 6. in /var/www/clients/client1/web1/web/vendor/shopware/core/Content/ProductExport/Service/ProductExportRenderer.php:118\nStack trace:\n#0 /var/www/clients/client1/web1/web/vendor/shopware/core/Content/ProductExport/Service/ProductExportGenerator.php(166): Shopware\Core\Content\ProductExport\Service\ProductExportRenderer->renderBody(Object(Shopware\Core\Content\ProductExport\ProductExportEntity), Object(Shopware\Core\System\SalesChannel\SalesChannelContext), Array)\n#1 /var/www/clients/client1/web1/web/vendor/shopware/core/Content/ProductExport/Api/ProductExportController.php(178): Shopware\Core\Content\ProductExport\Service\ProductExportGenerator->generate(Object(Shopware\Core\Content\ProductExport\ProductExportEntity), Object(Shopware\Core\Content\ProductExport\Struct\ExportBehavior))\n#2 /var/www/clients/client1/web1/web/vendor/shopware/core/Content/ProductExport/Api/ProductExportController.php(62): Shopware\Core\Content\ProductExport\Api\ProductExportController->generateExportPreview(Object(Shopware\Core\Framework\Validation\DataBag\RequestDataBag), Object(Shopware\Core\Framework\Context))\n#3 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpKernel.php(146): Shopware\Core\Content\ProductExport\Api\ProductExportController->validate(Object(Shopware\Core\Framework\Validation\DataBag\RequestDataBag), Object(Shopware\Core\Framework\Context))\n#4 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpKernel.php(68): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(Symfony\Component\HttpFoundation\Request), 1)\n#5 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/Kernel.php(201): Symfony\Component\HttpKernel\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)\n#6 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Symfony\Component\HttpKernel\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)\n#7 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Production\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)\n#8 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)\n#9 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)\n#10 /var/www/clients/client1/web1/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)\n#11 /var/www/clients/client1/web1/web/vendor/shopware/core/HttpKernel.php(148): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)\n#12 /var/www/clients/client1/web1/web/vendor/shopware/core/HttpKernel.php(77): Shopware\Core\HttpKernel->doHandle(Object(Symfony\Component\HttpFoundation\Request), 1, true)\n#13 /var/www/clients/client1/web1/web/public/index.php(83): Shopware\Core\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request))\n#14 {main}”}}
Hat jemand eine Idee an was es liegen kann ?
Gruß
Stefan Schulz
