Gelöst: Eigenes Cookie definieren?
Versuche aktuell in SW6 ein eigenes Cookie zu definieren, der gewünschte Effekt stellt sich leider nicht. Oder sagen wir mal so, ich sehe mein Cookie im Cookie-Manager nicht. Müsste doch aber zu sehen sein.
Hier mal mein bisheriger Versuch an der SW6 Dokumentation (Add cookie to manager) orientiert:
MeinPlugin\src\Resources\config\service.xml
<?xml version="1.0" ?>
<container xmlns="http://symfony.com/schema/dic/services"
           xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
           xsi:schemaLocation="http://symfony.com/schema/dic/services http://symfony.com/schema/dic/services/services-1.0.xsd">
    <services>
       <service id="MeinPlugin\Service\CustomCookieProvider"
                decorates="Shopware\Storefront\Framework\Cookie\CookieProviderInterface">
             <argument type="service" id="MeinPlugin\Service\CustomCookieProvider.inner" />
         </service>
    </services>
</container>
MeinPlugin\src\Service\CustomCookieProvider.php
<?php declare(strict_types=1);
namespace MeinPlugin\Service;
use Shopware\Storefront\Framework\Cookie\CookieProviderInterface;
class CustomCookieProvider implements CookieProviderInterface {
  private CookieProviderInterface $originalService;
    public function __construct(CookieProviderInterface $service)
        $this->originalService = $service;
    private const singleCookie = [
        'snippet_name' => 'cookie.name',
        'snippet_description' => 'cookie.description ',
        'cookie' => 'cookie-key',
        'value' => 'cookie value',
        'expiration' => '30'
    // cookies can also be provided as a group
    private const cookieGroup = [
        'snippet_name' => 'cookie.group_name',
        'snippet_description' => 'cookie.group_description ',
        'entries' => [
                'snippet_name' => 'cookie.first_child_name',
                'cookie' => 'cookie-key-1',
                'value'=> 'cookie value',
                'snippet_name' => 'cookie.second_child_name',
                'cookie' => 'cookie-key-2',
                'expiration' => '60'
    public function getCookieGroups(): array
        return array_merge(
            $this->originalService->getCookieGroups(),
                self::cookieGroup,
                self::singleCookie
Update: Habe es selber hinbekommen.
Wärst du so nett und teilst die Lösung hier?
Wäre cool wenn du uns auch die Lösung sagst!
Würde andere auch super weiterhelfen!
Generell mit jedem Controller möglich. Man muss nur den Response anpassen:
Wie würde das ganze in einem Subscriber funktionieren?
Nach meiner Verständnis hat dort nichts mit Cookie zu suchen. Damit Shopware das eigene Cookie auch im Cookie-Manager aufnimmt und akzeptiert, muss das ganze als Service angelegt werden. Hierzu gibt es eine Beschreibung (nichts anderes habe ich auch verwendet).
=> Add Cookie to Manager | Shopware Documentation
@R4M
Ist der cookie manager auch für localStorage oder sessionStorage geeignet? Weil hier gibt es im Grunde kein Cookie, aber im Consent sollte man auch solche steuern können?!
