Liebes Forum
Ich habe heute Morgen mehrfach diese Fehlermeldung bekommen:
Message: exception ‚Shopware\Components\CSRFTokenValidationException‘ with message ‚The provided X-CSRF-Token is invalid. Please go back, reload the page and try again.‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/CSRFTokenValidator.php:161
Stack trace:
#0 [internal function]: Shopware\Components\CSRFTokenValidator->checkFrontendTokenValidation(Object(Enlight_Controller_ActionEventArgs))
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(143): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚indexAction‘)
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#7 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#14 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
Time: 2016-11-03T08:43:58.652075+0100
Channel: core
request: {
„uri“: „/konfigurator/86/tischtuch_bella?c=33“,
„method“: „POST“,
„query“: {
„c“: „33“,
„module“: „frontend“,
„controller“: „detail“,
„action“: „index“,
„sArticle“: „86“,
„rewriteUrl“: „1“,
„sCategory“: „33“
„post“: {
„group“: {
„6“: „42“,
„12“: „118“,
„8“: „46“,
„10“: „69“,
„11“: „73“
„__csrf_token“: „“
session: No session data available
shopId: 1
shopName: meinshop
Dass sie mehrfach gekomen ist liegt wohl daran, dass es sich um einen Variantenartikel handelt und mehrere Varianten durchgespielt wurden.
Woran könnte das liegen ? Irgendwas mit X-CSRF-Token, wobei ich leider keine Ahnung habe, was das ist. Bei Wikipedia steht etwas von einem Angriff auf die Website. Besteht da ein Sicherheitsproblem ?
Liebe Grüße
Kerstin
