Extending Shopware entity with foreign keys fails when merging version
I’m developing my first Shopware 6 admin plugin, for which is required to extend one of the existing Shopware plugins - Custom products.
I want to add a relation between already existing entities - TemplateExclusion and TemplateOptionDefinition . When I select from the UI my options, TemplateExclusion entity its getting saved in the database, without any problems.
When I save the Template entity (parent of TemplateExclusion) , my „excluded_option_id“ its getting overwritten with the 1st possible option from TemplateOptionDefinition entities.
I have notice that this is happening on „mergeVersion“. Also when I try to save the Template entity with debug mode enabled and profiler, I’m getting an error during saving, that „excludedOptionId“ is blank when merging, which is not true.
Following the documentation I made first the migration:
class Migration1643023742TemplateExclusionRelation extends MigrationStep
    public function getCreationTimestamp(): int
        return 1643023742;
    public function update(Connection $connection): void
        $connection->executeStatement('ALTER TABLE `swag_customized_products_template_exclusion` ADD COLUMN `excluded_option_id` BINARY(16) AFTER `template_version_id`;');
        $connection->executeStatement('ALTER TABLE `swag_customized_products_template_exclusion` ADD COLUMN `excluded_option_version_id` BINARY(16) AFTER `excluded_option_id`;');
        $connection->executeStatement('ALTER TABLE `swag_customized_products_template_exclusion` ADD CONSTRAINT `fk.swag_cupr_template_exclusion.excluded_option_id` FOREIGN KEY (`excluded_option_id`, `excluded_option_version_id`)
        REFERENCES `swag_customized_products_template_option` (`id`, `version_id`) ON DELETE CASCADE ON UPDATE CASCADE;');
then I made an entity extension, where to define the new fields.
class TemplateExclusionExtension extends EntityExtension
    public function extendFields(FieldCollection $collection): void
        $collection->add(
            (new FkField('excluded_option_id', 'excludedOptionId', TemplateOptionDefinition::class))
                ->addFlags(new Required(), new ApiAware())
        $collection->add(
            (new ManyToOneAssociationField('excludedOption', 'excluded_option_id', TemplateOptionDefinition::class))
                ->addFlags(new ApiAware())
        $collection->add(
            (new ReferenceVersionField(TemplateOptionDefinition::class, 'excluded_option_version_id'))
                ->addFlags(new Required(), new ApiAware()),
    public function getDefinitionClass(): string
        return TemplateExclusionDefinition::class;
Update:
It was related to wrong field definition, correct ones are
        $collection->add(
        $collection->add(
            (new OneToOneAssociationField(
                EasyExtendCustomizedProducts::TEMPLATE_EXCLUSION_EXCLUDED_OPTION_EXTENSION,
                'id',
                false
            ))->addFlags(new CascadeDelete(), new ApiAware())
