How can it bee I can’t find a docs og link to how i edit the content the Footer content?
I can add links and so on, but there is the old footer under it, og the default phone no. on the side.
Is there no way in the backend editor were you can edit it easy? Do we need to go ind the files in the server and code it? SHould there not be a small update were that comes to the „frontend“ so it easy to edit?
Hope somebody can help me out - before i go a bit more crasy haha…
You can change the phone number in the backend. Just go to settings and then „Snippet“. You should find the right snippet right there where you can change the phone number. There is also a little bit of documentation for it. You can find it right here: Shopware 6 - Settings - Snippets
If you want to customize your footer even more you probably need to create your own theme and do it that way.
