hello, i am new to this and i have the following question
currently i am using a themeware cloud theme, and have a transparent header on my mainpage, problem is that its also transparent on my secondary page for exemple the catagoriepage. is there a way to use the Css class on the side of the module options to change the background of the header to for example white?
not sure if this is in the right place. hope someone could help
