Call external API once the stock level updated
I am going to create a plugin. This plugin will call external API once the stock level updated (i.e. decrease qty). My plugin file contains the following code. I can’t find var_dump or expected output not display. :
scheduleClearCache(ActivateContext::CACHE_LIST_DEFAULT);
    public function deactivate(DeactivateContext $context)
        $context->scheduleClearCache(DeactivateContext::CACHE_LIST_DEFAULT);
    public function uninstall()
        return true;
    public function install()
        # this event will be used after saving the order in the database
        return [
            'Shopware_Modules_Order_SaveOrder_ProcessDetails' => 'OnOrder_SaveOrderProcessDetails',
    public function onOrder_SaveOrderProcessDetails(Enlight_Event_EventArgs $args)
       // get SKU of Order items
       // Write here a qty you want to update on external
       //CURL code will place here
Hello,
other than in Shopware 5 in Shopware 6 the base classes of a plugin are no longer an event subscriber automatically. You will have to add an own subscriber class and add it to your services.xml file, if you want to subscribe to an event. Please also refer to our documentation for further reads https://docs.shopware.com/en/shopware-platform-dev-en/internals/plugins/plugin-quick-start?category=shopware-platform-dev-en/internals/plugins
Best regards from Schöppingen
 Michael Telgmann
I have Shopware version 5.X
[@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann „Michael Telgmann“)‍  I have implemented as per plugin guide
I will move the thread then…
Have a look at our Shopware 5 documentation please Developing plugins
[@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann „Michael Telgmann“)‍ I have created a plugin as per above document. Plugin created and active. Show in the backend as expected. I have tried lots of way but can’t get ride out this.
I can’t get an event which allow me call extenal API.
Main Plugin File
        return true;
        return [
            'Enlight_Controller_Action_PostDispatchSecure_Frontend_Checkout_Finish' => 'OnOrder_SaveOrderProcessDetails'
        $basketContent = $args->getDetails();
	    $order = $args->getSubject();
	    $orderNumber = $order->sOrderNumber;
	    var_dump ($basketContent);
Config File :
            Korona Pos
             API Token
             API Token
            API Tken
            An API token provided by Support.
Have a look here: Shopware events
you have to implement the getSubscribedEvents method
cool Michael Telgmann
 public static function getSubscribedEvents(){
        return [
You mean this??
[@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann „Michael Telgmann“)‍  Most recent as per document :
        return [
yes, that should work
Ok I will review once again. Might minor mistek
I would like to update you. can you check the source code? Because I have check all things still no outcome
[@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann “Michael Telgmann”)‍ Is it possible to check?
is your plugin installed and activated?
Btw: Have you already seen our online trainings? https://academy.shopware.com/collections?category=english-trainings They are really helpful for beginners  Smile
[@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann “Michael Telgmann”)‍ I have Hook issue which called some other place. Can you guide me I want to implement external API. I have code written in code PHP.
Correct place :
return [
'Shopware_Modules_Order_SaveOrder_ProcessDetails' => 'getAccountController'
This is the same which I follow.
Folder structure in Core PHP
Api.class.php // Contain Base class and functions
Helper.class.php // I have added some method
index.php // Execurtable file where all include
require_once("KoronaApi.class.php");
require_once("KoronaHelper.class.php");
// Prepare Data Set
$token = "Token";
// Organization which Manage warehouse and other things
$orgNo = "1";
// A SKU or Number must same as both site ecommerce and korona
$productNumber = "BLVK.Choco";
$qty = 10; // QTY you want to update Minus (-) indicate
// An Object manage stock
$KoronaObject = new KoronaHelper();
echo $KoronaObject->StockAdjustment($token,$orgNo,$productNumber,$qty);
Fatal error : Class ‚SwagTest\Subscribers\Helper‘ not found in /custom/plugins/SwagTest** /Subscribers/SwagTest **Subscriber.php  on line  6
Thank you for help. [@Michael Telgmann](http://forum.shopware.com/profile/17553/Michael Telgmann “Michael Telgmann”)‍ Its solved.
