I’m using Shopware 6 and want to create a custom theme. So I followed the manual and installed my “custom” theme. I started with some SCSS and ran the command “bin/console storefront:hot”. Then I visited my webshop and noticed that the style isn’t compiled. I kept the command line open with the command and changed my file, went back to the terminal and noticed that a change was found and the compile command didnt do anything. I decided to take a closer look at the terminal output:
Starting Execution of ‘storefront:hot’ (’/Users/donnyvangrondelle/Sites/Shopware/client-name/development/dev-ops/storefront/actions/hot.sh’)
(1/2) Starting
> bin/console theme:dump
(2/2) Starting
> APP_URL=https://shopware-nl.local PROJECT_ROOT=/Users/donnyvangrondelle/Sites/Shopware/client-name/development/ ESLINT_DISABLE=true npm --prefix vendor/shopware/platform/src/Storefront/Resources/app/storefront/ run-script hot
At the last line, I’ve spotted that the command is compiling the theme that is in the vendor folder and not the on in the custom/plugins/MyTheme.
Anyone has a answer for me? Am I doing something wrong?
Thank you!
