# Problem bei Versandart "Selbstabholung"
**URL:** https://forum.shopware.com/t/problem-bei-versandart-selbstabholung/51658
**Category:** Administration
**Created:** [9. März 2018 um 15:20 UTC](https://forum.shopware.com/t/problem-bei-versandart-selbstabholung/51658 "2018-03-09T15:20:17Z")
**Posts on this page:** 1
**Page:** 1
<div class="post-metadata">
### Author: ![solaradmin](https://avatars.discourse-cdn.com/v4/letter/s/c77e96/32.png) [@solaradmin](https://forum.shopware.com/u/solaradmin)
#### Post date: [9. März 2018 um 15:20 UTC](https://forum.shopware.com/t/problem-bei-versandart-selbstabholung/51658/1 "2018-03-09T15:20:17Z")
</div>
Hallo, ich habe für SW5.4 gemäß Dokumentation die Versandart “Selbstabholung” angelegt, erhalte aber beim Selbsttest folgende Fehlermeldung:
**Fatal error** : Uncaught Shopware\Components\CSRFTokenValidationException: The provided X-CSRF-Token for path “/checkout/saveShippingPayment/sTarget/checkout/sTargetAction/index” is invalid. Please go back, reload the page and try again. in /var/www/clients/client1/web2/web/engine/Shopware/Components/CSRFTokenValidator.php:149 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator-\>checkFrontendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs)) #1 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(220): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(176): Enlight\_Event\_EventManager-\>notify(‘Enlight\_Control…’, Object(Enlight\_Controller\_ActionEventArgs)) #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispat in&nbsp; **/var/www/clients/client1/web2/web/engine/Shopware/Components/CSRFTokenValidator.php** &nbsp;on line&nbsp; **149**
Woran kann das liegen?
