# priceStartingFrom manipulation for subshop with article attributes to disable article variants
**URL:** <https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378>\
**Category:** Programmierung\
**Created:** [9. November 2017 um 16:49 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378 "2017-11-09T16:49:52Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![logTom](https://dub1.discourse-cdn.com/flex013/user_avatar/forum.shopware.com/logtom/32/13273_2.png) [@logTom](https://forum.shopware.com/u/logTom)\
**Post date:** [9. November 2017 um 16:49 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378/1 "2017-11-09T16:49:52Z")
</div>
we developed a plugin that adds an attribute to articles and article variants.
The attribute is there to disable some variants of products in one of the subshops.
Now we have an article with 3 variants.
Test variant1 for 30 € (this variant should be disabled in the subshop)
Test variant2 for 40 €
Test variant3 for 50 €
Because the cheapest variant is disabled the “priceStartingFrom” if the article is wrong in the subshop.
Via these hooks
‘sArticles::sGetArticleById::after’
‘sArticles::sGetArticlesByCategory::after’
we modified the article listings to incorporate this.
Now we can’t get this working with the aritcle slider widget using a product stream.
> <https://github.com/shopware/shopware/blob/5.3/engine/Shopware/Bundle/EmotionBundle/ComponentHandler/ArticleSliderComponentHandler.php>
here at Line #165
$requestedProducts = $collection-\>getBatchResult()-\>get($key);
My first guess is to modify the price of the products in $requestedProducts if they have variants with the given attributes.
Are there any hooks or events to do this easily? I can’t see a solution other than direct manipulate the code.
I also tried to modify the price in the theme at
shopware/themes/Frontend/Bare/frontend/listing/product-box/product-price.tpl
but I can’t figure out how to get the article variants in there.
Any ideas how to handle that?
**Post date:** [13. November 2017 um 08:51 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378/2 "2017-11-13T08:51:16Z")
</div>
pump!
**Post date:** [14. November 2017 um 15:03 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378/3 "2017-11-14T15:03:10Z")
</div>
pump! Is something not understandable?
**Author:** ![mowlwurf](https://avatars.discourse-cdn.com/v4/letter/m/77aa72/32.png) [@mowlwurf](https://forum.shopware.com/u/mowlwurf)\
**Post date:** [14. November 2017 um 15:30 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378/4 "2017-11-14T15:30:55Z")
</div>
I had a similar problem, needed to modify articles within the article slider component. I also requested a simple hook event but there isn’t for this component
[https://forum.shopware.com/discussion/49152/eventcomponenthandler-kein-eventfilter-in-shopware-5-3#latest](https://forum.shopware.com/discussion/49152/eventcomponenthandler-kein-eventfilter-in-shopware-5-3#latest) (if you are able to read&nbsp;german)
So I needed to decorate the StructConverter
// in your Bootstrap
public function install(){
    $this->subscribeEvent(
         'Enlight_Bootstrap_AfterInitResource_shopware_emotion.emotion_struct_converter',
         'decorateEmotionStructConverter'
public function decorateEmotionStructConverter()
        $coreService = Shopware()->Container()->get('shopware_emotion.emotion_struct_converter');
        $eventManager = Shopware()->Container()->get('events');
        $converter = Shopware()->Container()->get('legacy_struct_converter');
        $structConverter = new \MyPlugin\ComponentHandler\StructConverter($coreService, $eventManager, $converter);
        Shopware()->Container()->set('shopware_emotion.emotion_struct_converter', $structConverter);
// the decorated struct converter
// excluded my modifyProduct function
class StructConverter
     * @var \Shopware\Bundle\EmotionBundle\Service\StructConverter
    private $service;
     * @var \Enlight_Event_EventManager
    private $eventManager;
     * @var LegacyStructConverter
    private $converter;
     * StructConverter constructor.
     * @param \Shopware\Bundle\EmotionBundle\Service\StructConverter $service
     * @param \Enlight_Event_EventManager $eventManager
     * @param LegacyStructConverter $converter
    public function __construct(\Shopware\Bundle\EmotionBundle\Service\StructConverter $service, \Enlight_Event_EventManager $eventManager, LegacyStructConverter $converter)
        $this->service = $service;
        $this->eventManager = $eventManager;
        $this->converter = $converter;
     * @param Emotion $emotion
     * @return array
    public function convertEmotion(Emotion $emotion)
        return $this->service->convertEmotion($emotion);
     * @param Element $element
     * @return array
    public function convertEmotionElement(Element $element)
        $elementArray = json_decode(json_encode($element), true);
        $elementArray['component']['xType'] = $element->getComponent()->getType();
        $elementArray['component']['cls'] = $element->getComponent()->getCssClass();
        $elementArray['data'] = array_merge($element->getConfig()->getAll(), $element->getData()->getAll());
        $elementArray['data']['objectId'] = md5($element->getId());
        switch ($element->getComponent()->getType()) {
            case BannerSliderComponentHandler::COMPONENT_NAME:
                return $this->service->convertEmotionElement($element);
            case BannerComponentHandler::COMPONENT_NAME:
            case ArticleComponentHandler::COMPONENT_NAME:
                if (!$element->getData()->get('product')) {
                $elementArray['data']['categoryId'] = (int) $elementArray['article_slider_category'];
                $product = $this->converter->convertListProductStruct($element->getData()->get('product'));
                $product = $this->modifyProduct($product);
                $elementArray['data'] = array_merge($elementArray['data'], $product);
                break;
            case ArticleSliderComponentHandler::COMPONENT_NAME:
                if (!$element->getData()->get('products') || !array_filter($element->getData()->get('products'))) {
                    break;
                $products = $this->converter->convertListProductStructList($element->getData()->get('products'));
                foreach ($products as $key=>$product) {
                    $products[$key] = $this->modifyProduct($product);
                $elementArray['data']['values'] = array_values($products);
                break;
            case CategoryTeaserComponentHandler::COMPONENT_NAME:
            case ManufacturerSliderComponentHandler::COMPONENT_NAME:
            case BlogComponentHandler::COMPONENT_NAME:
        return $this->eventManager->filter('Legacy_Struct_Converter_Convert_Emotion_Element', $elementArray, ['element' => $element]);
I hope this may help you.
Greetings
**Post date:** [20. November 2017 um 08:05 UTC](https://forum.shopware.com/t/pricestartingfrom-manipulation-for-subshop-with-article-attributes-to-disable-article-variants/49378/5 "2017-11-20T08:05:40Z")
</div>
Thanks you. I didn’t use your code because it’s legacy and not using the 5.2 plugin system. But it pointed me in the right direction that I need to use a decorator.
