# Decimals and Thousends Separator
**URL:** <https://forum.shopware.com/t/decimals-and-thousends-separator/64935>\
**Category:** Administration (EN)\
**Created:** [22. Februar 2020 um 21:22 UTC](https://forum.shopware.com/t/decimals-and-thousends-separator/64935 "2020-02-22T21:22:14Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![jnuricumbo](https://dub1.discourse-cdn.com/flex013/user_avatar/forum.shopware.com/jnuricumbo/32/13321_2.png) [@jnuricumbo](https://forum.shopware.com/u/jnuricumbo)\
**Post date:** [22. Februar 2020 um 21:22 UTC](https://forum.shopware.com/t/decimals-and-thousends-separator/64935/1 "2020-02-22T21:22:14Z")
</div>
Hi all,&nbsp;
My currency (Peso MXN) was&nbsp;not available in the installation process, so I decided to used Euro as default. Then I created a new MXN currency, but I don’t know how can I change the decimal and Thousends separator, I need&nbsp;967,295.00 instead of&nbsp;967.295,000
How&nbsp;can I achieve that?
Thank you!
**Author:** ![Moritz\_Naczenski](https://dub1.discourse-cdn.com/flex013/user_avatar/forum.shopware.com/moritz_naczenski/32/7792_2.png) [@Moritz\_Naczenski](https://forum.shopware.com/u/Moritz_Naczenski)\
**Post date:** [23. Februar 2020 um 08:01 UTC](https://forum.shopware.com/t/decimals-and-thousends-separator/64935/2 "2020-02-23T08:01:06Z")
</div>
Shopware uses php-intl extension to get the currency formatting. When the combonation of locale and&nbsp;currency ISO is set up correctly, it should work.
