# Call function only for particular plugin
**URL:** <https://forum.shopware.com/t/call-function-only-for-particular-plugin/45840>\
**Category:** Plugins\
**Created:** [18. Mai 2017 um 09:26 UTC](https://forum.shopware.com/t/call-function-only-for-particular-plugin/45840 "2017-05-18T09:26:27Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![joycopper007](https://avatars.discourse-cdn.com/v4/letter/j/a698b9/32.png) [@joycopper007](https://forum.shopware.com/u/joycopper007)\
**Post date:** [18. Mai 2017 um 09:26 UTC](https://forum.shopware.com/t/call-function-only-for-particular-plugin/45840/1 "2017-05-18T09:26:27Z")
</div>
I’ve created this event to validate our plugin and it 's working fine with our plugin but when i am trying to save other plugin “PayPal” configuration, i am getting “Form PayPal could not be saved” error msg, so how i can prevent to call “validateForm” this function to other form submit event.
//Event which I’ve created in bootstrap file
$this-\>subscribeEvent(‘Shopware\_Controllers\_Backend\_Config\_Before\_Save\_Config\_Element’, ‘validateForm’); &nbsp;
**Author:** ![DanielNogel](https://avatars.discourse-cdn.com/v4/letter/d/96bed5/32.png) [@DanielNogel](https://forum.shopware.com/u/DanielNogel)\
**Post date:** [18. Mai 2017 um 14:05 UTC](https://forum.shopware.com/t/call-function-only-for-particular-plugin/45840/2 "2017-05-18T14:05:23Z")
</div>
actually this is a little tricky, as the event does not hold any information, which plugin is currently being checked. So in your case I’d recomment to create a whitelist of elements, that should be checked. If the current element is not in your whitelist, you can just ignore it in your callback. If the element is in the whitelist, you can validate it.&nbsp;
Could that be a solution for you?
