# 500 internal error nach installation auf domainfactory
**URL:** <https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495>\
**Category:** Installation/Einstieg\
**Created:** [7. Februar 2017 um 18:07 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495 "2017-02-07T18:07:05Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![nafreilich](https://avatars.discourse-cdn.com/v4/letter/n/4da419/32.png) [@nafreilich](https://forum.shopware.com/u/nafreilich)\
**Post date:** [7. Februar 2017 um 18:07 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/1 "2017-02-07T18:07:05Z")
</div>
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at [no address given] to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
&nbsp;
habe die zip entpackt und auf den FTP geladen. nach auslösen der Domain&nbsp;[http://inspinnity.de/](http://inspinnity.de/) kam sofort&nbsp;[http://inspinnity.de/recovery/install/](http://inspinnity.de/recovery/install/)
hat jmd nen tipp für mich?&nbsp;
Danke schon mal&nbsp;
Flo
**Post date:** [10. Februar 2017 um 20:44 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/2 "2017-02-10T20:44:19Z")
</div>
hat hier keiner nen Tipp für mich dies bezüglich ? :(&nbsp;
**Author:** ![Vitago\_GmbH](https://avatars.discourse-cdn.com/v4/letter/v/67e7ee/32.png) [@Vitago\_GmbH](https://forum.shopware.com/u/Vitago_GmbH)\
**Post date:** [10. Februar 2017 um 21:29 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/3 "2017-02-10T21:29:30Z")
</div>
Schau mal ob dein Server die Systemanforderungen erfüllt&nbsp;[http://community.shopware.com/Systemanforderungen\_detail\_1840.html](http://community.shopware.com/Systemanforderungen_detail_1840.html)
**Author:** ![TimmeHosting](https://dub1.discourse-cdn.com/flex013/user_avatar/forum.shopware.com/timmehosting/32/15580_2.png) [@TimmeHosting](https://forum.shopware.com/u/TimmeHosting)\
**Post date:** [12. Februar 2017 um 17:10 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/4 "2017-02-12T17:10:26Z")
</div>
Gibt es eine entsprechende Fehlermeldung im Error-Log der Website oder in den Shopware-Logs?
![](https://europe1.discourse-cdn.com/flex013/uploads/shopware/original/1X/385eaa628505df573ebf33722f780335f53ac1b2.png)
[www.timmehosting.de](https://timmehosting.de/)
**Post date:** [14. Februar 2017 um 07:30 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/5 "2017-02-14T07:30:38Z")
</div>
> [@TimmeHosting schrieb:](https://forum.shopware.com/profile/9009/TimmeHosting "TimmeHosting")
> ![image](https://europe1.discourse-cdn.com/flex013/uploads/shopware/original/1X/385eaa628505df573ebf33722f780335f53ac1b2.png)
gibt es schon Logs wenn ich noch nicht mal mit der Installation angefangen habe?
&nbsp;
VG Flo&nbsp;
**Post date:** [15. Februar 2017 um 22:00 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/6 "2017-02-15T22:00:16Z")
</div>
Das Error-Log der Website gibt es auf jeden Fall, das ist unabhängig von Shopware.
**Author:** ![kraftmischer](https://avatars.discourse-cdn.com/v4/letter/k/a9a28c/32.png) [@kraftmischer](https://forum.shopware.com/u/kraftmischer)\
**Post date:** [19. Februar 2017 um 08:16 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/7 "2017-02-19T08:16:36Z")
</div>
Kann es sein, dass bei dir die .htaccess fehlt?
War bei mir auch so, passiert gerne, wenn du lokal das zip entpackst und dann per FTP hochlädst.
Wir sind auch bei DF, funktioniert eigentlich alles.
Was noch wichtig ist, ist der Pfad in der .htaccess:
RewriteEngine on
RewriteBase / &nbsp;
&nbsp;
&nbsp;
**Author:** ![Glaha](https://avatars.discourse-cdn.com/v4/letter/g/f14d63/32.png) [@Glaha](https://forum.shopware.com/u/Glaha)\
**Post date:** [27. Mai 2019 um 12:47 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/8 "2019-05-27T12:47:05Z")
</div>
ich habe ein ähnliches Problem.
Ich konnte alle Installieren. das Frontend wird angezeigt. Nur ins Backend komme ich nicht rein.
Die .htaccess habe ich bereits geändert und es geht leider immer noch nicht. Wo könnte mein Denk Fehler sein.
Domain: [shop-test.glaha-creatives.de](http://shop-test.glaha-creatives.de)
&nbsp;
-\> Es ist meine erste Installation von Shopware. ![Undecided](https://europe1.discourse-cdn.com/flex013/uploads/shopware/original/1X/8ae622c50104e84c5003fedfcc22572813a67b41.png "Undecided")
RewriteEngine on
#RewriteBase /
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
&nbsp;
**Author:** ![Moritz\_Naczenski](https://dub1.discourse-cdn.com/flex013/user_avatar/forum.shopware.com/moritz_naczenski/32/7792_2.png) [@Moritz\_Naczenski](https://forum.shopware.com/u/Moritz_Naczenski)\
**Post date:** [27. Mai 2019 um 12:51 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/9 "2019-05-27T12:51:12Z")
</div>
Also bei dir funktioniert Mod\_Rewrite nicht. Am besten schaust du mal, wie man es bei deinem Hoster aktiviert. Ggf. reicht hier das einkommentieren der RewriteBase, wie in diesem Thread genannt schon aus.
**Author:** ![kulli](https://avatars.discourse-cdn.com/v4/letter/k/a3d4f5/32.png) [@kulli](https://forum.shopware.com/u/kulli)\
**Post date:** [28. Mai 2019 um 09:43 UTC](https://forum.shopware.com/t/500-internal-error-nach-installation-auf-domainfactory/43495/10 "2019-05-28T09:43:05Z")
</div>
> [@Glaha schrieb:](https://forum.shopware.com/profile/31666/Glaha "Glaha")
> Hallo,
Was hast Du denn an der htaccess geändert ? Bei einer normalen Installation muss man nichts ändern…
