tiny_mce.js - Cannot read property 'body' of undefined
Hallo.
Wir bekommen den Fehler beim Aufruf eines Artikels im Backend. In beiden Fällen Shopware Version 5.5.7. Bei einer anderen 5.5.7 Instanz besteht dieser Fehler nicht. Woran könnte das liegen? Sollte laut dem hier schon längst behoben sein: https://issues.shopware.com/issues/SW-20306
Uncaught TypeError: Cannot read property 'body' of undefined
    at Editor.getBody (tiny_mce.js?201901211535:1)
    at Editor.setContent (tiny_mce.js?201901211535:1)
    at base?file=bootstrap&loggedIn=1551346080:10461
    at i.replacePlaceholderWithImage (base?file=bootstrap&loggedIn=1551346080:10355)
    at i.setValue (base?file=bootstrap&loggedIn=1551346080:10456)
    at Object.e (ext-all.js?201901211535:21)
    at Object.each (ext-all.js?201901211535:21)
    at Object.iterate (ext-all.js?201901211535:21)
    at i.setValues (ext-all.js?201901211535:21)
    at i.loadRecord (base?file=bootstrap&loggedIn=1551346080:4104)
getBody @ tiny_mce.js?201901211535:1
setContent @ tiny_mce.js?201901211535:1
(anonymous) @ base?file=bootstrap&loggedIn=1551346080:10461
replacePlaceholderWithImage @ base?file=bootstrap&loggedIn=1551346080:10355
setValue @ base?file=bootstrap&loggedIn=1551346080:10456
e @ ext-all.js?201901211535:21
each @ ext-all.js?201901211535:21
iterate @ ext-all.js?201901211535:21
setValues @ ext-all.js?201901211535:21
loadRecord @ base?file=bootstrap&loggedIn=1551346080:4104
loadRecord @ ext-all.js?201901211535:21
(anonymous) @ /backend/Article/load/?f=m/Batch|m/PriceGroup|m/PropertyGroup|m/PropertyOption|m/Template|m/Category|m/Media|m/SeoCategory|m/Unit|m/Similar|m/Accessory|m/Article|m/Price|m/Detail|m/Link|m/Download|m/Esd|m/EsdFile|m/Statistic|m/Serial|m/Configurator|m/ConfiguratorGroup|m/ConfiguratorSet|m/ConfiguratorOption|m/ConfiguratorTemplate|m/Dependency|m/PriceVariation|m/Field|m/Stream|m/MediaMapping|m/MediaMappingRule|m/Property|v/detail/Toolbar|v/detail/Window|v/detail/Settings|v/detail/Properties|v/detail/Prices|v/detail/Base|v/category/Tree|v/category/Seo|v/category/List|v/category/DropZone|v/image/List|v/image/Info|v/image/DropZone|v/image/DataView|v/image/Mapping|v/image/NewRule|v/image/Progress|v/variant/List|v/variant/Configurator|v/variant/Detail|v/variant/NumberProgress|v/variant/Progress|v/variant/ImageRelationProcess|v/variant/configurator/Dependency|v/variant/configurator/Sets|v/variant/configurator/GroupEdit|v/variant/configurator/OptionEdit|v/variant/configurator/Mapping|v/variant/configurator/Template|v/variant/configurator/PriceVariation|v/variant/configurator/PriceVariationRule|v/esd/List|v/esd/Detail|v/esd/Serials|v/statistics/List|v/statistics/Chart|v/crossselling/Tab|v/crossselling/Base|v/crossselling/ProductStreams|v/resources/Links|v/resources/Downloads|store/Batch|store/Detail|store/CategoryPath|store/CategoryTree|store/Variant|store/Group|store/Option|store/Esd|store/EsdFile|store/Statistic|store/Serial|store/Variation|store/Dependency|store/ConfiguratorSet|store/MediaMapping|store/Property|c/Main|c/Detail|c/Category|c/Media|c/Variant|c/PriceVariation|c/Esd|c/Statistic|c/Crossselling&no-cache=1551346080+1+1:1360
Keiner eine Idee zu diesem Thema?
Der Fehler tritt bei uns ebenfalls auf.
Beim erneuten Aufruf des Artikels klappt es dann auf einmal.
Durchh den JS-Fehler werden die Stammdaten des Artikels nicht zuende geladen.
So fehlen z.B. die Daten für Artikelnummer, MwSt., Template etc.
Hier eine weitere Meldung aus einem identischen Beitrag:
https://forum.shopware.com/discussion/59888/shopware-backend-uncaught-typeerror-body-von-tiny-mce-js
https://forum.shopware.com/discussion/57018/artikel-editieren-felder-werden-geleert
Der Fehler tritt anscheinend nur im Chrome auf und wenn viele Attributte vorhanden sind.
Schließe mich an. Habe genau den gleichen Fehler. Nutze Shopware 5.5.8 und die aktuellste Chrome Version 74.0.3729.131.
Bei uns hat es geholfen, diesen Timeout von 10 auf 1000 zu erhöhen:
Shopware 5.4.5
Chrome 75.0.3770.90
1 „Gefällt mir“
https://github.com/shopware/shopware/blob/5.4/themes/Backend/ExtJs/backend/article/controller/main.js#L367
Shopware 5.4.5
Chrome 75.0.3770.90
Danke für den Tipp. Werde ich gleich mal ausprobieren.
Das ist aber nicht updatesicher oder?
Das problem ist mit der allerneuesten version behoben
Shopware 5.4.5
Chrome 75.0.3770.90
Hat bei uns funktiniert.
Kann leider derzeit noch nicht updaten da nicht alle Plugins kompatibel.
Hallo, gab es hierzu von Shopware mal eine Info? Wir haben ein Problem in Version 5.5.4 “TypeError: this.getDoc(…) is undefined” vom TinyMCE. Das führt dazu, dass im Backend die Stammdaten nicht korrekt geladen werden und dann beim Speichern verloren gehen - hier haben wir inzwischen nicht ganz abzuschätzenden Datenverlust.
